Hello
I have a integral recip Clark VRA-12 three stage (three throw) compressor offshore,
first stage: 25" bore cyl
second stage: 16.5" bore cyl
third stage: 10.5" bore cyl
300 rpm
flow rate 5 MMscfd (nat gas 0.65 sg), 40-1200 psi, 70 deg F inlet gas. All three cylinders are double acting (all valves loaded)
I've been reading several other posts and refer to Hysys simulator. Is it possible to estimate the blowdown volume to atmosphere during a normal shutdown using a spreadsheet to calculate this for example?
I appreciate any guidance that you could provide
Mino
