What Is A Cpi Separator?
Posted 11 June 2014 - 12:10 PM
Posted 11 June 2014 - 04:37 PM
Try Google. It will answer your question.
Ayush:
If you use the Goggle Search Engine you will find:
A CPI (corrugated plate interceptor) Oil Separator is an oil-water gravity separator, developed with Shell’s technology, and is suitable for oily wastewater treatment. CPI Oil Separator enables high efficiency gravity separation with corrugated plates, providing excellent treatability with a high flow rate. The simple structure makes it possible to reduce the construction cost and facilitates maintenance.
1. The corrugated plates are located at short intervals, providing high oil-water separation efficiency. This makes it possible to stably treat rainwater even when the amount of rainwater treated is two or even four times larger than usual.
2. Compared to the PPI (Parallel Plate Interceptor), the CPI Oil Separator requires about 2/3 the installation area.
3. Compared to the PPI, the CPI Oil Separator has a relatively low construction cost.
4. The simple structure facilitates maintenance.
5. The CPI Oil Separator uses a molded synthetic resin that is highly resistant to corrosion, acid, and alkali, such as FRP, and is suitable for water quality.
6. The compact structure eliminates any concern about plastic deformation.
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
Gas-Liquid Separator Design With CondenserStarted by Guest_shambola_* , 16 Jan 2025 |
![]() Discharge Scrubber And Suction SeparatorStarted by Guest_Falah_* , 21 Jul 2024 |
![]() Flash Drum And SeparatorStarted by Guest_Abdellahi_* , 28 May 2024 |
