how do you estimate the number effects needed for a series of evaporators without considering economic costs involved? If this is possible? what are the parameters/ variables needed?
thanks..
Posted 05 July 2014 - 10:12 PM
thanks..
Posted 06 July 2014 - 03:05 AM
Posted 06 July 2014 - 03:39 AM
thank you Sir Breizh but nowhere in the page you have given is telling me how to estimate the number of effects. Anyway, I asked my friend about this and he mentioned something like in an evaporator system of N effects 1 lb of steam fed to the first effect will evaporate in all about N lbs of liquid. He said it's some sort of an observation and he doesn't have any theoretical proof of this.
Posted 06 July 2014 - 03:56 AM Best Answer
Hi PainRinnegan 25
table 8-1 should support your request !
Posted 06 July 2014 - 08:02 AM
ah ok i get it now..i wasn't paying attention on the table..it's true then, in an evaporator system of N effects 1 lb of steam fed to the first effect will evaporate in all about N lbs of liquid...you guys are amazing!.thanks a lot Sir..
![]() Rising Film EvaporatorStarted by Guest_lanco_* , 23 Jun 2025 |
![]() How To Estimate The Circulation Rate For Amdea (Mdea 45Wt + Pz 5Wt) BeStarted by Guest_tokotof_* , 29 Nov 2024 |
![]() Heat Transfer In Jacketed EvaporatorStarted by Guest_haseeb00718_* , 19 Aug 2024 |
![]() Multiple Effect Evaporator Calculation With Multiple ComponentsStarted by Guest_addiesalsabil_* , 13 Jan 2024 |
![]() Troubleshooting Of Wfe - ( Wiped Film Evaporator)Started by Guest_DivineFist001_* , 29 Nov 2023 |
