Heat Exchanger - Shell Side Velocity Limitation
#1 rasprocess
rasprocess
  • 36 posts
Posted 16 July 2014 - 05:52 AM
Hi
I am looking for criteria for shell side fluid velocity. there are criteria for tube side velocity in several references , but I have not found any criteria for checking shell side velocity in exchanger datasheets.
I will appreciate you if you give me some help
sincerely yours
  • 6,982 posts
Posted 16 July 2014 - 06:28 AM
http://www.chemstati...cles/shell.pdfs
consider this resource to support .
Srfish , our expert or other members should  support your query.
#3 PingPong
PingPong
  • 1,474 posts
Posted 16 July 2014 - 06:48 AM
In heat transfer there is a simple rule: the higher the velocity the better the heat transfer coefficient.
However:
- the maximum allowable shell side velocity is set by tube vibration limitation.
- moreover: the maximum shell side pressure drop that you allow also limits the allowable shell side velocity.
#4 srfish
srfish
  • 408 posts
Posted 16 July 2014 - 09:40 AM
PingPong is right. "The maximum allowable shell side velocity is set by tube vibration limitation". Good software will alert you to a shell side velocity problem. HTRI has a whole chapter on this subject. The solution to a vibartion problem depends on whether this is an existing heat exchanger or an analysis of a thermal design. A short discussion of vibration can be found in pages 140-144 of "Heat Transfer in Process Engineering" by Cao.
#5 Chinmoy_ChE
Chinmoy_ChE
  • 4 posts
Posted 24 November 2014 - 04:22 AM
Hi
sincerely yours
I had the opportunity to be in one of the Xist training session. One of the trainee asked the same question about shell side velocity.
Answer from the trainer as I remember, "It is very difficult to define velocity range for shell side fluid. The basic criteria for shell side design is to maximize B stream (Cross Flow stream). In HTRI results you can find different fraction of stream for a specific design.
Please go through "Effectively Design Shell-and-Tube Heat Exchangers by Rajiv Mukherjee, CHEMICAL ENGINEERING PROGRESS • FEBRUARY 1998" for more information.
Edited by Chinmoy_ChE, 24 November 2014 - 04:24 AM.
