Reading Motor Voltage Ratings
motorac 230vac 460vac supply voltage motor voltage motor specs
#1 Subject_Name_Here
Subject_Name_Here
  • 30 posts
Posted 18 August 2014 - 12:24 PM
I’ve noticed on most motors the supply rating is mentioned in the following fashion:
“230/460 Volts AC—Rectangular Outlet. Operates on 208-230/460 Volts AC”
My question is does the motor run off 230v or 460v? Does the 230/460 mean it can run off either voltage? Also Why does it then mention 208-230/460?
Thank you!
Posted 18 August 2014 - 01:45 PM
Read the attached GE brochure - especially page 2.
Attached File  AC Motor Selection & Application Guide.pdf   275.69KB   42 downloads
#3 Subject_Name_Here
Subject_Name_Here
  • 30 posts
Posted 19 August 2014 - 10:28 AM
Thank you!
