I am doing school project using distillation column.
Control programs will be three including delta v.
Our high temperature will be 100.
What type insulation material do i need to use for it?
Edited by hiseana, 29 August 2014 - 04:23 PM.
Posted 29 August 2014 - 04:19 PM
Posted 29 August 2014 - 08:10 PM
100 what? oF oC oR oK ?
What are the chemicals being seperated?
What is the material of construction of the distillation column?
Is column inside or outside?
What is the climate and extremes?
What are dimensions of column?
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Teg Dehydration Stripping ColumnStarted by Guest_SidRah_* , 08 Sep 2025 |
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
