Maximum Allowable Pressure Drop For Control Valve
control valve pressure drop
#1 hoyar
hoyar
  • 9 posts
Posted 02 September 2014 - 02:27 PM
Is there any limitation or criteria for maximum allowable  pressure drop in a flow control valve?
I have a water stream with pressure around 120 bar, water will pass through a control valve and pressure after CV will be around 50 bar. is this control valve usual? is this pressure drop acceptable for CV?
#2 Chemengineer112
Chemengineer112
  • 17 posts
Posted 03 September 2014 - 03:39 AM
 Dear  hoyar ,
The design drop  across  the  valve  is  sometimes  expressed  as  a
percentage of the friction drop in the system, exclusive of
the valve. A good working rule is that 50% of this friction
drop should be available as drop across the valve. In
other words, one-third of the total system drop, including
all  heat  exchangers,  mixing  nozzles,  piping    is
assumed to be absorbed by the control valve.
 For valves installed in extremely long or high-pressure drop
lines, the percentage of drop across the valve may be
somewhat  lower,  but  at  least  15%  (up  to  25%  where
possible) of the system drop should be taken.
#3 PingPong
PingPong
  • 1,474 posts
Posted 03 September 2014 - 05:35 AM
If you have to reduce the water pressure from 120 to 50 bar then you can do that with a control valve.
In Hydrocrackers control valves are used to let liquid down from a separator at ~150 bar to a separator at ~10 bar, whereby that liquid is moreover flashing. Those valves are expensive but it is possible.
