All,
Last week we have an explosion(the explosion part will not be addressed). now it is time to determine what happened. There are ideas running around as to what happened. As we all know, everyone has an opinion. i am seeking for practical explanation and calculations that can support my idea. First i think it is a vacuum event. the vessel is jacketed. dowtherm is used in the jacket to heat up the oligomer. we had to spin out the plant a few weeks ago, but we could not flush/empty this vessel.we thought that during start up we will just melt the oligomer and push it through the process. the followings are my questions and comments.
1- the shell and jacket are rated for full vacuum. How can a rated FV fail under vacuum? the actual nameplate shows FV @ 600F. Can temperature affect the vacuum rating of a vessel. i still can't understand how a FV rated vessel failed under vacuum. how can one explain it? if this a possibility how to you determine this pressure?
2- during the outage i think there was an exothermic reaction taking place in the vessel (thermal degradation of Oligomer/PET). at some point last week we realized that the temperature and pressure in the line was building up we decided to stop the dow supply to this vessel. i think the exothermic reaction heat was enough to evaporize the dow that was in the jacket. after about 20 min of the dow pump being down, a decision was made to rapidly cool off of the system.(this is what i think caused the failure. condensing the dow on the jacket side)
3- My main goal is to come up with calculations that can explain the vacuum failure on the jacket. if you see anything the attached picture please share.
Please see the attached vessel for visual failure
