yea, i agreed with you.
However, it’s already stated in the datasheet as per attached which friction loss is 120m which is equivalent to 11bar. Yes, i agreed with you, 16 barg is high even already highlighted by client. Normally 10 barg. How do I confirm the operating pressure in the main ring? Is it by having fire water pump curve?
Refer attachment for the sketch. Refer point J6 in the red circle. At that point, (i assume after deluge valve) I do try and error by plug in any value for pressure at that point until i get the desired flow at the end of each spray. Normal flowrate for each spray is 20 liter/min. Based on calculation report (after insert all the value for the pipe length, fittings based on isometric dwg), calculated required pressure at that point is around 9 barg (which is the pressure drop across deluge valve should be 7barg if the upstream pressure is 16barg) to deliver 20 l/m for each spray. Does it look convincing? Appreciate to comment
farid.k,
It's not normal having such pressure drop across a deluge valve; but the data sheet you attached isn't included this data. Indeed, the pressure of 16 barg appears to be high for fire water network. Anyway, if a simple sketch of the system being uploaded can help to submit better response...
