We are trying to evaluate some low pressure rated equipment relief requirements, design pressure ~2.5 psig. The vessels and equipment are indoors in a well drained, sprinkler protected environment with a good fire fighting brigade. Due to the low pressure rating of the systems we are leaning toward API-2000 methodology. However when calculating heat absorption rates we are getting nearly double the vapor generation rates of API-521 using the 21,000 BTU/hr/SF heat flux equation.
Has anyone applied the allowable environmental F factor of 0.5 (good drainage/impounding)when using API-2000 methodology for similar scenario's?
Debating using API-521 methodology vs API-2000 with F=0.5 for acceptable heat absorption.
Any thoughts appreciated.
Open Fire Heat Absorption
Started by Guest_Guest_gpeters_*, Aug 21 2003 05:48 PM
No replies to this topic
Posted 21 August 2003 - 05:48 PM
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
Heat Exchanger Temperature CrossStarted by Guest_kaidlut_* , 20 Dec 2022 |
Waste Heat BoilerStarted by Guest_Prim_* , 25 Apr 2026 |
