Thermodynamic Model For Flash Calculation
thermodynamic model;flash
#1 chem2013
chem2013
  • 36 posts
Posted 20 September 2014 - 03:39 AM
Hi Everyone,
I need to perform a flash calculation to estimate quantities that will go into vapour phase from liquid phase. I have water and contaminates in it like H2,H2S,C3,C4,C5,C6+. Please advise correct thermodynamic model for Aspen Plus/Aspen Hysis.
Regards.
  • 6,818 posts
Posted 20 September 2014 - 05:11 AM
http://www2.questcon...mo/thermot.html
Consider this resource , this may help you.
#3 chem2013
chem2013
  • 36 posts
Posted 21 September 2014 - 09:49 AM
Actually water is about 99.0 % and rest is contaminants. I am not sure whether peng robinson is a correct model . Please advise.
Regards.
#4 serra
serra
  • 311 posts
Posted 22 September 2014 - 01:45 AM
You do not specify operating temperature and pressure,  Without these it is difficult to propose a suitable model,
For near atm conditions you may adopt a simple model starting, for example, from some equilibrium constants (i.e. H2S in water etc. solubility).  For higher pressures a EOS with complex mixing rules should do the work,
Predictive EOS models may be considered, too.  I use a different software (PRODE PROPERTIES) and I
do not know the models available in Aspen.  However, the above should provide reasonable results.
#5 yudho_pr
yudho_pr
  • 3 posts
Posted 03 October 2014 - 02:01 AM
For flash calculation, besides composition you have to have pressure and temperature. Peng & Robinson is okay.
