Dear members,
Why bronze impeller is used in chilled water pumping system?
Edited by Chem32, 10 October 2014 - 11:18 PM.
Posted 10 October 2014 - 11:17 PM
Dear members,
Posted 10 October 2014 - 11:21 PM
Bronze is corrosion resistant in that environment. And it is not overly expensive.
Posted 11 October 2014 - 01:08 AM
Dear sir,
Our cooling water and chilled water system will have same TDS and pH.
For cooling water we are using cast iron impeller, for chilled water we are using bronze impeller. Why this difference?
Posted 15 October 2014 - 10:21 PM
Hi Chem32
HVAC vendor usually uses bronze impeller for the chilled water pumps. Maybe the material selection come from the diferent basis. for example piping can be referred to asme b31.1 for power plant and b31.3 for process plant.
Posted 16 October 2014 - 05:18 AM
What is the temperature of chilled water you are dealing with.
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , Yesterday, 08:17 AM |
Waste WaterStarted by Guest_refluxraider_* , 14 Apr 2024 |
Water Seal DrumStarted by Guest_Ali4269278331_* , 05 Apr 2024 |
Handling The Limited Capacity Of Flare SystemStarted by Guest__1angelia23_* , 05 Apr 2024 |
Closed Drain SystemStarted by Guest_Falah_* , 26 Mar 2024 |
