Navier Stokes Equation For Non Newtonian Fluid ?
#1 Engineer in making
Engineer in making
Posted 30 November 2014 - 05:33 PM
Hi everyone,
I'm trying to solve a fluid problem for isothermal, steady, unidirectional laminar flow of an incompressible non-Newtonian. And was asked to solve the navier stokes equation ( Momentum equation) for it. Here's the diagram:
http://prntscr.com/5bwfli
Shear stress formula :
http://prntscr.com/5bwful
Mementum equation:
http://prntscr.com/5bwdbu
My solution:
http://prntscr.com/5bweal
I'm just wondering If my approach for the problem and my solution was right since I'm having doubts about my solution.
  • 6,722 posts
Posted 01 December 2014 - 01:17 AM
http://en.wikipedia....tokes_equations
Hope this  helps
Edited by breizh, 01 December 2014 - 01:21 AM.
#3 ahmadikh
ahmadikh
  • 42 posts
Posted 02 December 2014 - 02:47 PM
Navier-Stokes equation in X direction should be used to achieve the velocity profile...As stated in the attachment provided by Breizh, remember that for non-Newtonian fluids, the type of fluid should be known in order to determine the shear stress change as a function of velocity gradient.
The pressure gradient term (dP/dx) in X direction is missing in your equation. Assuming the following assumption your solution is fine, except the pressure gradient term is missing:
1) There is no motion in Y and Z direction (Uy = Uz = 0)
2) Ux is only function of Y (dUx/x = 0)
3) Steady State Condition (dUx/dt = 0)
4) There is no velocity gradient in X and Z direction, so no shear stress (Txz = Txx = 0)
Hope this helps...
Best,
Milad
