All,
I just remember i had this great forum. since i moved to the production side of the business i am crazy busy (not visiting this site as often as i used to). Anyway i have a problem. My plant makes polyester resin (PET). i have a desuperheater that helps saturate the superheated dowterm. given the poor heat transfer on the heat exchanger downstream of the desuperheater, i started the process of elimination. one of the things i do not know how to cross out is the desuperheater. How to you troubleshoot a desuperheater? yesterday i decrease the degree of superheat but this not help a lot. something i noticed is that the condensate from the desuperheater is much hotter then the return from the heat exchanger returns, to me it make sense but a group of people at my at the site tend to believe that they should be equal.
Thank you,
