Dew Point Temperature Of Water In Natural Gas
#1 R NESAMANI
R NESAMANI
  • 73 posts
Posted 17 December 2014 - 01:24 AM
Dear all,
We want to calculate the dew point temperature© of water in natural gas.
We have the following details
1) Molecular wt of gas = 17.72
2) Water vapour = 110 ppm(v)
3) Pipeline pressure = 70 kg/cm2 g
4) Pipeline Temperature = 16.63 DegC
Can you help me with the formula to use?
  • 6,354 posts
Posted 17 December 2014 - 02:22 AM
R Nesamani
Consider the search feature in this forum :http://www.cheresour...ater-dew-point/
Hope this helps
#3 serra
serra
  • 310 posts
Posted 17 December 2014 - 03:29 AM
breizh has given a good advice, at cheresources you'll find several threads discussing this topic,
anyway, when composition is not available you may consider the graphical methods discussed in GPA,
here you may find a copy of McKetta , Wehe chart,
"http://petrowiki.org...thout_hydrates"
differently (composition available) accurate procedures are available based on estimates of fugacities of different components in the mixture,
for a numerical example see post 13# in thread
"http://www.cheresour...f-process-gas/"
