good morning every one, please i need a tutorials or books to configurate a fired heater ( dynamic and Steady State) in aspen one (hysys)
and an exemple of fired heater in refining distillation column. thank you
Posted 22 February 2015 - 09:27 AM
Posted 13 March 2015 - 01:08 PM
Firstly, fired heaters are dynamic. Heat exchangers can be both dynamic and steady state. Use fired heater if you really need the options inside, like the radiant and convective sections. I got some nice info for your reading.
https://www.google.c...heater tutorial
Posted 15 June 2015 - 01:20 PM
Depending on the level of detail you require, HySys is not able to accurately simulate a fired heater and provide reliable process and mechanical details. To carry out reliable simulations that provide results for No. of Radiant and Convection tubes, Avg Radiant Flux, Flue Gas Flow, Radiant and Convection duties, etc., your best option would be to use specialist fired heater simulation software.
There is a new software called Heater560 which is very easy to use and will actually generate a full heater design based on your minimal specified requirements. So if you only have basic information/requirements at this stage, that program would probably be best for you.
see more: fired heater simulation and Automatic fired heater design
Posted 31 October 2015 - 03:13 AM
Good morning,
Thanks for the information you shared about Fired heater simulation, I tried to download this software but unfortunately I found nothing.
Could you please help me find the heater560 software to download it.
Thanks.
Edited by Zineb Ka, 31 October 2015 - 03:13 AM.
Posted 01 November 2015 - 02:56 AM
You have to request for a 'free trial' the Heater560 software can be downloaded. The following link will take you to the page where you can request for this trial (someone usually responds very quickly!)
http://www.heatersim...ial---heatersim
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
![]() Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Why To Maintain The Skin Temperature At 150Degc In Fired Heater ?Started by Guest_johneyissac98_* , 12 Jan 2023 |
