Reboiler Tube Leak
#1 engineer54
engineer54
  • 6 posts
Posted 06 March 2015 - 08:44 AM
Dear Gentlemen,
We faced a leak in one of our reboilers , The leak was discovered during the warm up of the exchanger we found Hydrocarbons coming along with the steam condensate.
This exchanger is having a total number of 282 'U' Tubes.
Operating Parameters :
Tube side (L.P.S.) (P=3.5 kg/cm2 , Tin = 145 C, Tout= 141 C)
Shell side Liquid (MTBE+ C4's) ( P = 7.4 kg/cm2 , Tin = 82.7 C , Tout = 91.5 C )
Design Parameters :
Tube side (L.P.S) ( P= 6.4 Kg/cm2 , T = 320 C )
Shell side (MTBE + C4's) ( P = 9.5 KG/CM2 , T = 110 C )
What is the possible reasons that lead to such leak in this exchanger ?
Taking in consideration the following :
- This exchanger didn't cleaned by hydro jetting since 9 years.
- Operating Temperature of the shell side already noticed that it reach up to 130 C (More than design Temp), but this exchanger is made from Carbon steel (C.S).
After inspection it was found that 1 tube is leaked & 2 tube faced some mechanical defect.
Kindly share with me your observation & your valuable comments for the reasons of This leak  ??
#2 engineer54
engineer54
  • 6 posts
Posted 07 March 2015 - 07:02 AM
:) Any comments ?
#3 fallah
  • 5,026 posts
Posted 07 March 2015 - 07:14 AM
engineer54,
Please specify if the leak is from tube to tubesheet connection or is along the U-tube itself...
#4 Zauberberg
Zauberberg
  • 2,728 posts
Posted 07 March 2015 - 07:42 AM
It is impossible to specify the exact reason for the reboiler tube leak to occur. These can be numerous, and sometimes there are two or more combined effects which have led to a common consequence:
- Thermal shocks during startup/shutdown/trip
- Corrosion
- Vibration
- Overpressure of the tubes
- Improper material selection
- Mechanical deficiencies
and many other possible reasons. Your Inspection team should perform a detailed analysis of the leak points and narrow the investigation to one or two possible mechanisms of damage.
#5 Napo
Napo
  • 350 posts
Posted 07 March 2015 - 11:56 AM
Dear Engineer54,
In your problem there are many factors. You need an investigation for identification the causes. Maybe the most important problem is related with corrosion, you can review the API RP-571,  in Boiler water condensate corrosion, section 4, page 78.
Also I send you other documents that you can review.
I hope this help you.
Napo.
