Insulation Calculation For 3-Phase Separator Vessel
insulation
#1 venkyravula
venkyravula
  • 7 posts
Posted 04 May 2015 - 08:55 PM
Hi All,
I am working on a 3-phase separator design and I need to insulate complete vessel because of climate conditions in Winter. Temperature in winter may go down to -6 degC, minimum temperature need to be maintained inside the vessel is 26 deg C so that there is no hydrate formation or freezing of water takes place.
Material of construction of vessel is SA516 Gr 70N+ SS 904L Cald (5mm).
Thickness of vessel is 46 mm.
Vessel dimension: 3800 mm X 14000 mm T/T.
Gas flow: 1.93 MMscfd (1049038 kg/hr), gas density: 15.8 kg/m3 & Viscosity :0.012 cP
Oil flow : 448 m3/hr, liq density: 809.2 kg/m3 & Viscosity :2.910 cP
water flow: 631.00 kg/hr, density: 987.40 kg/m3 & Viscosity :0.53 cP
Insulation material: as suitable
I tried to calculate using normal pipe insulation formulas but I have 3 flows inside the vessel so I am not confident whether it is a correct approach or not.
Can anybody please help me how to calculate insulation thickness for vessel.
Thank you
Venky
#2 gegio1960
gegio1960
  • 518 posts
Posted 04 May 2015 - 11:14 PM
I think it's better to start by submitting your trial calculations for comments....
Then... wind conditions are missed and inlet temperature is not defined.
