Does anybody know how to generate Pro II output file with *.p2i extension?
Posted 20 May 2015 - 01:14 AM
Posted 20 May 2015 - 02:54 AM
In Provision:
click on Output, then select Report Format, select Miscellaneous Data and check the box called: Generate all Database Statements. Or check only those boxes that you are really interested in.
If you work with ASCII input files in PRO/II then include the statement DBASE DATA = ALL
just above the statement COMPONENT DATA.
Posted 20 May 2015 - 04:47 AM
thanks a lot
Mdea QuestionsStarted by Guest_Board operator_* , 09 Jun 2024 |
![]() Pe Chemical Practice Exam QuestionsStarted by Guest_AthlonXPme_* , 31 Mar 2024 |
Steam Reforming For Hydrogen-QuestionsStarted by Guest_daraj_* , 05 Nov 2021 |
[Pressure Swing Adsorption - Sizing Questions] Step By Step Method ToStarted by Guest_CamilleGroulx_* , 07 Oct 2020 |
Questions About Moving Bed Coal GasifierStarted by Guest_Jade331_* , 18 Aug 2020 |
