Hello Everyone,
i want to know what is the maximum differential pressure for which i can design a heat exchange.
When i say differential pressure i mean the difference in pressure of shall side and tube side fluid.
I have a case in which i have one hot liquid hydrocarbon stream which is at 855 psig (Tube side) and a cold Hydrocarbon stream which is at 85 psig (shell side). Can i use these stream for heat exchange.
The hot stream is Inlet temp is around 600F and outlet will be around 450 F, Please note Hot Stream may contain H2S but considering the temperature water will be saturated (i.e. no wet H2S).
if could use this i will be able to save a "fire heater" which is the only option to heat this cold stream.
if your answer is yes i would like to know few references too to justify my opinion.
Eagerly waiting for your response.
Jutesh
