Hi All
I have a project in Oil and Gas industrial, I need to blend Butane and Propane to LPG with some different scales. Please show me some solution for that.
Thanks!
Posted 02 June 2015 - 01:50 AM
Hi All
Thanks!
Posted 02 June 2015 - 02:42 AM
Hi there,
I wonder why would you mix 2 complete products into some lower value mixture?
But anyways, if you need to do that you just take 2 streams and mix it under flow control. what is the problem?
Posted 02 June 2015 - 03:24 AM
Ensuring that the blend meets the requirements for LPG, ofcourse.
Posted 08 June 2015 - 08:30 PM
My customer imports butane and propane and input into the tanks after that they are mixed to LPG and input to another tanks.
I know some solution to solve it: in-line blending or tank mixing.
Please help me solve that and send me some handbook if you have
Thanks and Regards,
Posted 09 June 2015 - 12:40 AM
Please refer to my earlier reply. You can do either tank mixing or line blending. But ensure that the mixture meets the requirements (specifications) for LPG in your country. Butane has lower vapor pressure than propane and LPG has in between vapor pressure. So mix both in a proportion so that the mixture will meet the vapor pressure requirement for LPG. You may use ASTM D 2598 for blending. . Other properties like copper corrosion, total sulfur, heavier components like pentane should, however, both meet.
Posted 09 June 2015 - 12:29 PM
Usually in summer and winter you need different ratios of propane/butane. Make sure you have reviewed the regulations and your client specification.
both of mixing methods can be used but make sure you have proper tanks and relevant facilities.
		Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025  |
		 Flash Seperation For N-Butane IsomerizationStarted by Guest_CHEMICAL_LOVER_* , 04 Dec 2024  |
		Propane Loss From Sphere TankStarted by Guest_rasprocess2026_* , 04 Nov 2024  |
		 Separation Of N-Butane From 1-Butene By Extractive DistillationStarted by Guest_Geetanjali_* , 21 Sep 2021  |
		Propane Product Temperature Correction FactorStarted by Guest_loggrrr_* , 20 Nov 2023  |
