Different Methods For Distillation Cut Points In Hysys
hysys column distillation
No replies to this topic
#1 AhmadMMoktar
AhmadMMoktar
  • 7 posts
Posted 10 June 2015 - 08:58 AM
Hello everyone,
HYSYS has in its column specs different ways to calculate the cut points (i. e. D86 5%, 95%,....), examples of these methods are:
1. column cut point spec.
2. End point based column cut points (that's for refsys).
3. column stream property .. then D86 ...%.
each one of these methods gives a different value from the others.
My question: does anyone know the different correlation used for each method, and what's the more accurate one as they give different results?
