Hi we are doing a revamp project where we need to eliminate the FIV from an existing reboiler. Presently it has H type shell . We evaluated that with the use of DS baffles - vertical cut, the FIV problem can be encountered. But we are not sure whether the use of vertical cut baffles in boiling service will produce any adverse effect or not. Please comment
Posted 11 June 2015 - 05:36 AM
Posted 11 June 2015 - 05:30 PM
What is FIV? I assume DS means double segmental baffles. In a boiling service I think vertical cut baffles would be better than horizontal cut. There would be less possibility of gasses being trapped.
Posted 12 June 2015 - 12:16 AM
Thanks...... FIV is flow induced vibration
Steam On Shell Side Of A Vertical HexStarted by Guest_Lyne_* , 09 Jul 2025 |
![]() ![]() Reciprocating Pump Acceleration Head With Vertical Pipe LineStarted by Guest_Sansan_* , 18 Oct 2024 |
Sizing Of Vertical/horizontal Flash DrumStarted by Guest_Mohammad3799_* , 10 Mar 2024 |
![]() Vertical Separators Best MethodStarted by Guest_fmalik_* , 02 Dec 2023 |
