Flare Design And Nearby Equipment
flare
#1 Sue N
Sue N
  • 19 posts
Posted 17 June 2015 - 10:30 AM
On an air assisted flare, certain wires/cables are required in the proximity of the flare to power the blowers. Additionally, certain structures (cable trays, panels) may also be required within a certain radius.
Since flare design is based on radiation (BTU/hr/ft2), how do plant designers ensure that the wiring/structures that approach the flare are rated for the temperatures that the equipment can reach?  Do they normally calculate expected temperatures (Ex: this black insulated wire should get to X degrees based on Y BTU/hr/ft2) or do designers normally assume a temperature limit based on prior experience?
#2 Napo
Napo
  • 350 posts
Posted 16 July 2015 - 06:02 PM
Sue N,
You can review Evans, Equipment Design Handbook, Vol. 2, Ch. 6, Flare Stack, here there is a reference: Kent G. R. "Find Radiation Effects of Flares", Hydrocarbon Processing, June 1968, p. 119.
I hope help you.
Napo.
