I work in a petrochemical industry. My question is that there is a Carbon Steel pipe for handling Liquid Propylene. Prior to charging Propylene into this line, we have filled this line with 3 bar N2 gas. Now i want to know how will I calculate the final temperature of Propylene after flashing inside the pipe. I want to know the lowest temperature so that I can check if its matching with the minimum design temperature of the CS pipe.
