Out Of Range Flow Meter
flow meter
#1 ezralh
ezralh
  • 32 posts
Posted 27 June 2015 - 11:22 AM
Hi all,
I have a few flow meters which always give out of range reading (higher side). For example if the high range is 100 kg/h it give 100 kg/h, I could not know the actual flow since it has gone beyond the range . I plan to re range the flow meter, but the problem is how can I get the correct range. Appreciate if you can give some advice..
  • 6,718 posts
Posted 27 June 2015 - 08:29 PM
ezrahl ,
Probably good for you to check the data sheet associated to your flow meters and to discuss with the vendor . BTW difficult to say much not knowing the technology and having no information about the action you have been taking to solve the problem or to confirm the reading ..
#3 farid.k
farid.k
  • 384 posts
Posted 30 June 2015 - 01:40 AM
Hi all,
ezrahl,
for me the best solution is, you can rent a portable flowmeter from relevent contractor, ask them to do on-site flowrate checking, and from that value, you can make that as basis for the flowmeter re-range.
#4 Zauberberg
Zauberberg
  • 2,728 posts
Posted 30 June 2015 - 01:50 AM
I don't know which are the fluids and process units in question here, but usually it is possible to calculate material balance around the plant (or at least obtain a decent estimate of flows) by looking at an overall diagram showing in/out streams. If you can get these figures, you may be able to obtain those that are missing.
