Heat Exchanger Performance Calculation
#1 aanita
aanita
  • 105 posts
Posted 05 September 2015 - 01:22 AM
Can any one help me how to calculate heat exchanger performance, preferably in an excel sheet.
  • 6,797 posts
Posted 05 September 2015 - 02:44 AM
aanita ,
1)
http://www.hcheattra....com/tools.html
Will it help ?
2)
The other possibility is to conduct mass & heat balances and compare them with the data sheet of your equipment .
Good luck.
Edited by breizh, 05 September 2015 - 03:02 AM.
#3 walidd_23
walidd_23
  • 27 posts
Posted 05 September 2015 - 03:24 AM
you can use Kern's method, by the calculation of the required Area and compare it with the installed area,
Find attached  My  excel spreadsheet  for a sipmle calculation.
#4 aanita
aanita
  • 105 posts
Posted 05 September 2015 - 11:18 AM
Thank you very much.
#5 Bobby Strain
Do you want to check performance of an operating exchanger for which you have collected data?
#6 aanita
aanita
  • 105 posts
Posted 06 September 2015 - 07:32 AM
Exactly Bobby. I have only operating temperature data in the heat exchanger. I try to find the differential temperature of heat exchanger and compare with original / clean condition. Since feed is too much fluctuation between design and actual figure, I am not interested HEX effectiveness factor or overall heat transfer coefficient of clean and actual condition.
#7 Bobby Strain
Posted 06 September 2015 - 02:36 PM
The only comparison to design is to calculate the heat transfer coefficient from your data. Which means you must calculate the effectiveness to derive the heat transfer coefficient. If the flow is significantly different from design, you can estimate expected performance by scaling the design conditions in the appropriate manner. I presume the performance is not acceptable; otherwise you would be working on other important things.
