I want to simulate a biological reaction, but the stoichiometry is not well known. How can I model this using SuperPro? What kind of reactor is suitable? Or for Aspen Plus
Posted 20 October 2015 - 10:29 PM
Posted 21 October 2015 - 02:45 AM
The answer depends on the meaning of "the stoichiometry is not well known". What is known about the reaction then?
Posted 21 October 2015 - 06:11 PM
Great question,
right now what is known is the conversion, and the products and starting reactants. The reaction scheme is very complex, so I don't think there is any way to model it using Aspen. I'm still trying to get kinetic data for the reaction. I heard biological reactions can often be modeled as first order, or possibly I can use michaelis kinetics.
This reaction has not been studied extensively, that is why not much is known and I don't have all the details. I'm just wondering from a modeling perspective what kind of reactor I can use if I don't have the stoichiometry for the reaction.
Posted 21 October 2015 - 07:28 PM
I found some information that gives michaelis-menten kinetic parameters Vmax and Km, so at least now I have something to work with.
Posted 21 October 2015 - 08:21 PM
What is the difference between a stoichiometric and kinetic reactor in SuperPro? They both require inputs of the stoichiometry, and I am trying to avoid that
Posted 22 October 2015 - 04:48 AM
Until know i can say that it is possible in Aspen +.
As a simple example i used a CSTR for the following typical MM mechanism of reaction:
S + E <==k_1/-1==> SE ==k2==> E + P
Which finally, after doing the math with MM assumptions, gives a reaction rate:
r = Vmax*[S]/(Km + [S])
, where:
r is expressed in kmol/m3-s;
Vmax=k2*E0, in kmol/m3-s;
Km= (k-1 + k2)/k1, in kmol/m3.
The substrate (S) and product (P) were introduced in component list using the water from databank and changed their ID.
The reaction type is 'general' class 'LHHW' in order to allow a rate expression which can be brought to the form we want.
Enzime molar concentration is included in Vmax.
For more details you can have a look in the file attached.
![]() Material Balance With ReactionStarted by Guest_Kentucky08_* , 30 Apr 2025 |
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
Aspen Hysys Dynamic Simulation Reforming ReactionStarted by Guest_fmalik_* , 07 Dec 2024 |
Depressuring Rate Reaction SectionStarted by Guest_Ade24_* , 20 Sep 2024 |
