Asphalt And Vacuum Residue Storage Tanks
Started by shahid780812, Nov 20 2015 09:36 AM
Posted 20 November 2015 - 09:36 AM
I am looking for the temperature rise on the ground beneath the storage tank bottom storing asphalt and vacuum residue at a storage temperature of 225 Dec.
The tanks are located on the circular ring type concrete foundation and beneath the bottom plate of tank, the concrete annular space isfilled with sand.
For proper design my civil team is looking for the temperature rise in the sand below the tank bottom plate.
Can anybody share the calculations done on this before...
Posted 25 November 2015 - 12:46 PM
Please reply, I am struggling to clear this issue..
Posted 25 November 2015 - 01:17 PM
shahid780812,
You can conservatively suppose the temperature rise to be an amount would cause the ground beneath the tank reaches to 225 C, i.e. same as the storage temperature...because calculation of actual temperature rise cannot be so simple...
Now, how would your civil team apply this temperature in relevant civil design?
Posted 25 November 2015 - 02:59 PM
Thank you very much Mr.fallah, i will check with my civil lead and update on this further.
Off Spec Condensate Storage TankStarted by Guest_shekhar dhuri_* , 05 Sep 2013 |
![]() Butadine Storage And HandlingStarted by Guest_engmmostafaa22_* , 08 Feb 2025 |
![]() Storage Tanks Diked Area Fire Protection Using Foam MakerStarted by Guest_mkhattaby_* , 30 Jan 2025 |
