Dear Experts
Greetings from me
We are Looking for Shell & Tube type Heat Exchanger
More specifically We are looking a condenser similar to the vertical tube & shell WSA Condenser.
We have a gas scrubber application where we want to cool 75 g/m3 of 98% Sulphuric Acid at 300 deg C from 4000 m3/h of ambient Air down to 40 deg C. I believe the air will absorb some of that heat so will be in the high 200s deg C overall.
We are not so concerned about sulphur recovery – and the amounts are very small. It is more to simply cool the air/sulphuric acid mix down to a 40 deg C temperature – or perhaps close to 100 deg C is sufficient.
Very Important :- Also We want to know the Pressure drop in shell as well as in Tube for air blown 4000 m3/h.The pressure drop has to be very very minimal
Now the heat transfer area needs to be big due to air flow rate you are also suggest if we can attach two Shell & Tube heat exchanger together
Kindly suggest me the best Heat Transfer area for this and also let me know for the given data what should be the water flow rate in shell and what kind of water will be preferred
Please help me for the same.
Vikas Gupta
Edited by vikas7475, 27 November 2015 - 07:38 AM.
