Hi, i have to heat a stream (LNG: from 50°C to 290°C at 70 bar) and the heat flof is 0.1141MW, so i must design i new fired heater ( i think the heat flow is very low) or heat exchanger, or other equipement. thank you.
Lng Vaporizer Design
Posted 05 December 2015 - 04:37 AM
Posted 05 December 2015 - 06:14 AM
titim
please clarify what your problem is.
Posted 06 December 2015 - 06:08 AM
hi, i have to design an equipement to heat a stream from 50°c toinlet 290°C with:
T (C°) =290
Posted 06 December 2015 - 10:59 AM
Why do you call this topic "LNG Vaporizer Design" when it seems to be about just heating a gas?
In any case, what heating medium you use depends on what is already available at your plant.
If you have hot oil of sufficient temperature, you could use that as a heating medium in a heat exchanger.
If you have hot steam of sufficient temperature you could consider using that in two heat exchangers in series: one desuperheating the stream, followed by one condensing the steam. Or, if there is sufficient steam, only one exchanger for only desuperheating that steam.
In the absence of any available heating medium you can use a fired heater, if you like.
But if the duty is only 114 kW you could simply use an electrical heater.
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
Condenser DesignStarted by Guest_Kentucky08_* , 07 Dec 2025 |
