Start Up Strainer
#1 Rahimzadeh
Rahimzadeh
  • 282 posts
Posted 18 December 2015 - 01:37 AM
Dears:
Please clear for me about neccesity of use start up strainer for every pump?
is there any standard about this?
best regards
M.R.Rahimzadeh
#2 fallah
  • 5,022 posts
Posted 18 December 2015 - 03:16 AM
Mr. Rahimzadeh,
As far as i know there is no special standard for necessity of using start up strainer in centrifugal pumps suction line; but in general a temporary cone type strainer is usually applied...
Edited by fallah, 18 December 2015 - 03:18 AM.
#3 breizh
  • 6,810 posts
Posted 18 December 2015 - 03:48 AM
Let you google "temporary strainer" , this is part of good practices at the start up to prevent damage to the rotating equipment.
#4 latexman
  • 1,849 posts
Posted 18 December 2015 - 07:09 AM
The local slang (my company/U.S.) for these temporary strainers is a "witches hat".
#5 manojkaila
manojkaila
  • 66 posts
Posted 19 December 2015 - 01:56 AM
Dear,
Normally start up strainer is used to avoid damage to rotary equipment internals & seals. During start up time we get the maximum foreign materials like debris,welding slag, rust, construction items like nut & bolts, gloves etc even after cleaning of the system. As per my experience normally we fixed 40 mesh Stainless steel mesh inside of the permanent strainer and after sufficient length of operation we need to remove once we confirm that nothing much is coming.
Manoj
#6 shvet
shvet
  • 135 posts
Posted 19 December 2015 - 10:57 PM
see API 686
"2.3.3 Any temporary or permanent strainer shall be located between the inlet isolation block valve and the machinery inlet connection"
There are a lot of rules and recommendations in API 686. For types and drawings of  temporary strainer see fig B.6.
Edited by shvet, 19 December 2015 - 10:57 PM.
#7 Dacs
Dacs
  • 457 posts
Posted 05 January 2016 - 02:05 AM
This is good (if not a MUST) practice to have one as the suction manifold can contain anything during start up (one cannot fully rely on pneumatic cleaning of lines to remove all debris inside a pipe).
