Hello, my name is Agustina I´m studying chemical engineering . I´m working on a proyect about THIOGLYCOLIC ACID, I wanted to know if someone could send me any infrmation you had about the manufacture process, as well as the machinery used, specially the reactors.
If not, it would be great if you could tell me how or where I could get this information or where to look for the size and production capacity of the diferent types of reactors.
Thank you very much
A.R.
Thioglycolic Acid
Started by NEGRA, Jun 02 2006 11:40 AM
Convertor Performance For Sulphuric Acid GenerationStarted by Guest_Ranga v_* , 01 Jun 2026 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Phosphoric Acid 56% Tank LiningStarted by Guest_Phosphoric123_* , 20 Apr 2025 |
