Hi
I am tasked with the design of a batch type catalyst plant. We have multiple mixing vessels and I am currently sizing a mixing vessels. I have a query on selecting the nozzle location for the vessel.
Solid Feed nozzle, Vent and PSV are selected on top head. Drain and outlet nozzle are selected on bottom head.
I have couple of inlet(feed) nozzles, hot and cold DM water connections for which I need to finalize the location.
There is no external heating coil or jacket. Agitator is present.
My operating conditions: pressure: Atmospheric, Temp: 30 deg C.
Feed: One solid inlet, DM water and phosphoric acid will be mixed to prepare a solution.
Given a choice and no other process constraint what is the preferred nozzle location- Vessel Head or on the Vessel.
Which is costlier? make a hole on head or on shell.
