I estimated the flow rate for control valve failure case is more than doubled compared to the normal through the CV.
I think that once the heat exchanger is selected with a design duty and fixed surface area, it is basically impossible for the heat transferred to double. This means that it is too conservative to assume the relief rate is simply the methanol that can be vaporized due to the extra LP steam supply available (Q=m.ΔH) , regardless of the heat transfer process (Q=U.A.ΔTlm) itself.
The more appropriate way is to estimate Q by estimating U and ΔTlm for the CV fail open case. However, it is very difficult to do so as a process engineer. I am thinking it might be possible if we have HRTI used by Heat Transfer Engineers.
Anyone has a better and yet simple way to estimate the relief rate for this case?
Thank you.
Leo
Edited by J_Leo, 11 April 2016 - 09:16 AM.
