I'm making an experiment to investigate the effectiveness of electrocoagulation method in separating oil in water emuslions. And I'm looking for a simple method for analysis (measuring the concentration of crude oil in water ), I know about standard methods but since the number of experiments I'm going to run are very large , I can't afford such methods. Turbidity measurment is not an option as well.
My hypothesis is as follows: for each sample (oil in water emuslion) I will add equal volume of normal hexane to extract the oil but instead of perfectly separating the extract from the remaining water I will just draw a very small portion of the extract using a pippet and take it for spectroscopy analysis. A claibration curve between light absorbance and known oil concentrations is created previously (no problem with this).
Would the oil concentration in hexane (after extraction) be homogenous so the concentration in the top layer is the same as in the bottom layer of hexane.
Hints: I don't need to measure the exact oil in water concentration but just the degree of removal resulting from different experiments. All sample will contain dissolved solids , emulsifier molecules, and suspened solids ( mainly aluminum hydroxide).
Thanks in advance
