Pd Pump Vs Viscosity
Started by processengeng, May 04 2016 06:53 PM
Posted 04 May 2016 - 06:53 PM
Hi everyone. I have a PD pump with the liquid viscosity ranging from 500-5000. I understand that the viscosity is one of the main parameter used to size a PD pump. Initially I provided data @ 5000 cp to pump vendor and informed that the pump shall be able to handle a lower viscous liquid (500 cp). Then vendor asked me the discharge pressure of pump at 500cp. Any one can advise how this will affect the selection of the PD pump? Thank you.
Posted 04 May 2016 - 07:15 PM Best Answer
Posted 04 May 2016 - 08:44 PM
Less viscosity = more slippage = less flow. Also, the flow of less viscosity is affected by pressure more than flow of high viscosity (more slippage).
Posted 05 May 2016 - 02:41 AM
The negative effect is very low, close to nil. Based on pump type, each of the viscosity values could be considered, at least as much time as the fluid is Newtonian.
Posted 05 May 2016 - 09:08 AM
Thank you everyone. Thank you Breizh, your material is very useful to me.
Turbine Driven PumpStarted by Guest_Rahimzadeh_* , Yesterday, 09:14 AM |
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
Heavy Crude PumpStarted by Guest_Rahimzadeh_* , 13 Apr 2024 |
Pump Sizing ConsiderationsStarted by Guest_panagiotis_* , 07 Apr 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
