hi everybody, i have a simple question: how can i calculate the air-cooler elevation from the ground
thank you.
Posted 15 May 2016 - 10:57 PM
thank you.
Posted 16 May 2016 - 04:26 AM
titim,
In general, it's installed on the nearest pipe rack; but should be located at a sufficient elevation above grade to allow the necessary volume of air to enter the fan such that the fan performance would be within proper range without hot air recirculation. It's obvious, at the elevation toward sea level, higher air density will result in higher heat removal capability provided that other parameters being kept unchanged...
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
![]() Air-Cooler Heat Exchanger - Unit Vs BayStarted by Guest_pymorty_* , 19 Dec 2023 |
Dry Cooler Vs Cooling TowerStarted by Guest_Quimarah_* , 10 Sep 2023 |
Air Cooler Fan ShutdownStarted by Guest_A.D._* , 13 Oct 2021 |
![]() One Air Cooler Instead Of TwoStarted by Guest_Movers_* , 30 Sep 2021 |
