please explain to me which direction hole should be punched in sieve tray. Top or Bottom?
Is it true that bottom punched holes gives less pressure drop as compared to Top punched holes.If yes,please elaborate the possible reasons.
Posted 17 June 2016 - 01:07 AM
Posted 17 June 2016 - 01:27 AM
Muhit Kumar,
It can be true because bottom punch hole will generate less entrance pressure drop against vapor passing movement through the hole...
Posted 17 June 2016 - 01:33 AM
wow..thanks for quick reply.
Is this also true with Valve tray.?
Can you tell me how significant will be the difference in Pressure drop because of hole punched direction
Posted 17 June 2016 - 01:43 AM
Muhit Kumar,
I think it cannot be applicable for valve tray....
Difference in pressure drop isn't so significant due to hole punch direction in sieve tray...
Posted 17 June 2016 - 01:49 AM
Fallah Sir,
For valve trays, Bottom orifice means flat orifice and top orifice means extruded orifice.
can it be the reason for different pressure drop as applicable in sieve trays?
Posted 17 June 2016 - 02:05 AM
Muhit Kumar,
It might be considered as an apparent reason, but in real world a valve tray isn't installed at the tray bottom hence cannot be an option for valve tray installation....
Posted 17 June 2016 - 08:29 AM
The reason that in sieve trays the holes are usually punched downwards is to avoid injury for personnel working inside the tower during installation, inspection or maintenance, since the punch exit is usually sharp or rough.
Disadvantage of punching downward, with the punch exit against the direction of the vapor flow, is increased pressure drop, so in situations where low tray pressure drop is essential the punch direction for sieve trays is usually specified by the design engineer to be upward.
Edited by PingPong, 17 June 2016 - 08:29 AM.
Posted 17 June 2016 - 07:11 PM
I leave tray details to the supplier (for 50 years). So your specification should include allowable pressure drop.
Organic Peroxide Distillation IssueStarted by Guest_Kimbreaux_* , 19 Feb 2026 |
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Teg Dehydration Stripping ColumnStarted by Guest_SidRah_* , 08 Sep 2025 |
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
Packaging And Gas Velocity In Packed ColumnStarted by Guest_ChemEng_CristianoB_* , 25 Jun 2025 |
