What's Amine Loading ? and how can we calculate it???
thank you.
Sarah.
Posted 04 August 2016 - 11:54 AM
thank you.
Sarah.
Posted 04 August 2016 - 01:11 PM
Acid gas concentration in the rich amine.
Posted 04 August 2016 - 11:03 PM
Hi Sarah ,
You may find good information using this link
http://www.refiningonline.com/ABPG_KB/
Posted 06 August 2016 - 11:25 AM
Hi Sarah,
If you are talking about the Rich Amine Loading (RAL) then it basically means how much of Acid gas was absorbed in the lean Amine passing through the absorber. it is calculated by subtracting the amount of acid gases escaping with sweet gas from the amount of acid gases in the sour gas (feed to the absorber) over the amount of MDEA or DEA..etc in the Amine solution entering the absorber. It should be in molar basis.
I hope this is helpful.
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Amine(Mdea) StorageStarted by Guest_abdullah1320_* , 17 Jun 2024 |
Dp Drop In Structured Packing Amine Absorber Causing IssuesStarted by Guest_kek12345_* , 10 May 2024 |
Amine System FiltrationStarted by Guest_Hanaa_* , 09 Jan 2022 |
Rich Amine Quality In Lpg Absorber TowerStarted by Guest_Alchemes_* , 21 Nov 2022 |
