Design A Centrifugal Gravel Pump
#1 Moepi
Moepi
Posted 23 October 2016 - 01:19 PM
I need to build a centrifugal pump with a 8" suction and discharge. Pump 8000l water per min and 48 cub m of gravel and sand per hour.Should be an "Africa" pump - easy to build,welded together
Any drawings or ideas would be appreciated
#2 Bobby Strain
Posted 23 October 2016 - 07:19 PM
Ask some of your pump suppliers. But you will need size distribution for the sand and gravel.
#3 shvet
shvet
  • 135 posts
Posted 23 October 2016 - 10:16 PM
There is a big market niche for special case pumps for mines. This kind of pumps is specially designed for sand and gravel (up to 50 mm dia.) pumping. There is a lot of companies and you can try to start with them.
Edited by shvet, 23 October 2016 - 10:19 PM.
#4 breizh
  • 6,786 posts
Posted 24 October 2016 - 05:07 AM
Just Google "centrifugal gravel pump design  " you will get plenty of references of suppliers .
Good luck .
