Sor &eor In Nht Unit
Started by moeinesmaeili, Nov 14 2016 04:23 AM
Posted 14 November 2016 - 04:23 AM
Hi, what's the meaning of sor &eor & Sor temperature ? The catalyst is Co_Mo(HR-506).
Why we have to sulfurized the catalyst that it's in oxide form?
Posted 14 November 2016 - 06:03 AM
Posted 22 December 2016 - 11:27 PM
Some sulfur is needed to activate the catalyst. In the very old days, we would simply allow the regular feed and its sulfur activate the catalyst, and rerun the off spec material produced during that time period. Today, there is a fancy procedure for sulfiding the catalyst before exposing the regular feed to it. SOR means start of run. EOR means end of run. A run is the period (6 mo.,12 mo., 24 mo., etc) during which feed is introduced before shutdown for catalyst regeneration or replacement.
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
