Compressor Suction Temperature
Posted 29 November 2016 - 12:42 PM
I have a question please. I deal with a gas its dew point -25 c and hydrate formation at suction pressure is -18 c.
The question is it possible to enter the gas at -10 c to the compressor, because there is no possibiliy to form hydrate or condensate at this temperature and pressure.
Your quick response is highly appreciated.
Posted 29 November 2016 - 01:10 PM
The rule of thumb is to operate natural gas systems at least 10 deg C above the hydrate formation temperature. If that is not possible, you can inject a hydrate inhibitor such as methanol or MEG upstream of the compressor suction scrubber . Hydrate inhibitors act to depress the hydrate formation temperature thus allowing operation at low temperatures.
Posted 29 November 2016 - 02:10 PM
Posted 01 December 2016 - 06:20 PM
Hi
Make sure,after compression the gas doesn't get cooled off much.It must remain atleast 10 Deg C above the hydrate formation temperature.
Because after compression,hydrate formation temp will also increase with the increase in discharge pressure.
Aditya
Caloric Temperature CalculationStarted by Guest_bckesim_* , 10 Apr 2024 |
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Fan Laws For Centrifugal Compressors And Varying Suction ConditionsStarted by Guest_SickPuppy0_* , 25 Jan 2023 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Design Gauge Pressure Inlet To A Centrifugal Compressor.Started by Guest_Mohammad3799_* , 03 Mar 2024 |
