Glucose/sucrose To Carbon
Started by jyoti1234321, Jan 26 2017 12:32 PM
inert glucose sucrose carbon atmosphere
Posted 26 January 2017 - 12:32 PM
Let Say we take 1 mole of glucose/Sucrose, then heat it up to 800 degree Celsius,
Case-1 (Inert 95%Ar-5%H2 atmosphere)
Case-2 (Air atmosphere)
Case-3 (N2 atmosphere)
then what reactions will happen in all those cases,
and what will be the carbon content we will get in the final product in each case.
Posted 26 January 2017 - 03:58 PM
Jyoti:
If this is an assigned homework problem, then please state so.
Our members are not free tutors and don't do homework for others to take credit. If you are having problems with understanding or working this problem, then so state it and submit your generated work on the subject. Our members will comment or recommend paths for you to take in leading to a resolution. But you have to do the leg work.
Our forum is not organized to do other people's homework. As a future engineer, you must EARN the right to graduate as a practicing engineer.
Activated Carbon SelectionStarted by Guest_Talhafarooq_* , 25 Nov 2024 |
Carbon Bed Filter CalculationsStarted by Guest_kyayura_* , 25 Jul 2023 |
Carbon Capture Absorber SimulationStarted by Guest_raisoturu_* , 21 May 2024 |
Activated Carbon Fire RiskStarted by Guest_TheChemEng_* , 03 Aug 2023 |
Carbon Filter Used In Hot Benfield Solution For Co2 Removal In AmmoniaStarted by Guest_Abhishek Taware_* , 14 Jul 2023 |
