Alloy Steel P 22 And P 11
Posted 30 January 2017 - 09:02 PM
Posted 31 January 2017 - 07:00 AM
Minimum tensile- and yield- strengths are the same 60 and 30 ksi(kilo psi) respectively for the both grades, but the maximum allowable stresses(MAS's) are different. The MAS's for grade p22 (2.25Cr-1Mo)are slightly higher than p11(1.25Cr-0.5Mo) for the temperature range 700~1200℉; see the table below (ASME/ASTM SA335).
Temp(℉) MAS, p11//p22, (ksi)
-20~700 15.0//15.0
750 14.8//15.0
800 14.4//15.0
900 13.6//13.6
1000 6.3//8.0
1100 2.8//3.8
1200 1.2//1.4
It seems that slightly higher contents of Cr and Mo make the higher MAS and resistance to oxydation at higher service temperatures.
~Stefano G Kim
Edited by sgkim, 06 February 2017 - 03:42 AM.
Max Wall Temperature Stainless SteelStarted by Guest_ChristianColombini_* , 23 May 2024 |
Cost Factor/index Table For Mocs Like Carbon Steel, Glass Etc.Started by Guest_daraj_* , 29 Aug 2021 |
Spark Potential Stainless SteelStarted by Guest_kangas_* , 03 Jun 2021 |
Equation For Heat Loss Through Carbon Steel PipeStarted by Guest_Process EngrPsh_* , 11 Dec 2019 |
Glass Flake Coating Vs Alloy Cladding On VesselsStarted by Guest_F.Sh_* , 23 Apr 2019 |
