We have a process condensate stripper operating at 31-32 barg pressure. Process condensate contains Methanol 890ppm, Ammonia 530ppm, CO2 1500ppm , Amines 200ppm. Total condensate flow is 42000 kg/hr. Condensate temp. is 215deg C. Steam used at 31bar g , 344 deg C condition and flow 16.5 MT/hr . Stripped Condensate analysis shows Methanol 9ppm, Ammonia 5ppm , CO2 NT, Amines 21ppm.Now I tried to simulate this tray tower of 20 nos of Valve trays in Aspen as well as Chemcad but I couldn't get desired result . Can anybody help me how can I simulate this column? Which property method will be useful?
Aspen Simulation Of Process Condensate Stripping At 31-32 Barg Pressur
Posted 17 February 2017 - 11:02 PM
Posted 20 February 2017 - 05:08 PM
Hi Hiren,
PC stripper works quite well in aspen plus. Use PSRK property method.
Kind regards,
Satyajit
Posted 21 February 2017 - 04:22 PM
Hi Hiren,
(1) ppm in wt or mol?
(2) what kind of amine?
(3) MT/hr = metric ton / hr?
Posted 25 February 2017 - 12:38 AM
@Satyjit Thanks for reply . I had tried using PSRK method as well but it's not effective for NH3,Amines and CO2 removal. NH3 remains in stripped condensate ,hardly any NH3 is stripped out. . In fact Chemcad suggested PSRK model for my system but it doesnot strip out the Ammonia . I think the problem lies due to combine of Methanol and Amine system hence any specific model for methanol or amine system doesnot work here.
@J_Leo Thanks. It's a CO2 removal process using activated 40% wt/wt MDEA solution . PPM is mass and yes Metric ton per hour.
Condensate Storage Tanks In-Breathing And Out-BreathingStarted by Guest_MethanolPlant_* , 26 Apr 2024 |
Simulating A Single Tube Heat Exchanger In Aspen HysysStarted by Guest_catia_* , 02 May 2024 |
Aspen Hysys Training Opportunities For Six Individuals Within Our InduStarted by Guest_Hafiz_Che_* , 30 Apr 2024 |
Aspen Plus Convergence ErrorStarted by Guest_NavidJon9_* , 29 Apr 2024 |
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catia_* , 22 Apr 2024 |
