Suction Line Sizing For A Compressor
#1 curious_cat
curious_cat
  • 475 posts
Posted 19 February 2017 - 06:33 AM
I've a  compressor working with relatively low pressures / compression ratios (it is part of a vapor re-compression system in a multi effect evaporator). I need to size the vapor suction line.
Is there a standard resource / guideline to do this? Is the pressure drop the governing criterion?
One guideline I got from a previous thread on this forum was:
 not to exceed density x velocity ^2 value of 15000 (SI units)
http://www.cheresour...for-compressor/
Is this a good guideline? e.g. For a case I was calculating (P=1 barg) it gives me line velocities of approx. 150 m/sec as still acceptable.
These seem too high to my intuition.
Another article gives the following guidelines:
"As a rule of thumb, suction and discharge lines should be sized for a maximum actual velocity of 30 ft/sec (1,800 ft/min) to 42 ft/sec (2,500 ft/min).'"
But this would mean a max velocity of only 10 m/sec. Way lower than what the 15000 limit on rho x v^2 seems to give.
A Norsok standard (Sec. 5.4.2) puts 60 m/sec as a general max limit for gas lines (nothing compressor specific)
Are there other guidelines on max velocities? Why so much conflicting rules of thumb.
Edited by curious_cat, 19 February 2017 - 07:15 AM.
#2 Bobby Strain
Posted 19 February 2017 - 01:52 PM
Generally one sizes the inlet and discharge piping based either on noise criteria or pressure loss. Here is guides from Elliott.
#3 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 20 February 2017 - 04:01 AM
Dear,
I would like to quote regarding compressor (centrifugal / reciprocating) from the standard of a globally reputed company:
Attached File  Sizing_Compressor_Lines.png   52.07KB   46 downloads
Additionally the most common sizing methodology would be based on source pressure and destination pressure (compressor inlet flange) i.e. the pressure drop in the suction system (piping / valves etc.)
Ankur
Edited by ankur2061, 20 February 2017 - 04:07 AM.
#4 curious_cat
curious_cat
  • 475 posts
Posted 20 February 2017 - 10:13 AM
Thank you very much Ankur and Bobby!
