Hello friends ;
I'm wondering please what API version should I refer to calculate set pressure , builtup back pressure ,
superimposed back pressure ,cold differential and permessible overpressure for PSV . The fluid il gasoil
THANKS A LOT !
These look like thermal relief valves.
If this is the case API STD 521 5.14.2 should be consulted.
There is no need to do too much extensive calculation and just a simple 3/4" x 1" valve to be used unless you suspect this is not enough for thermal relief (rare).
Set pressure can be design pressure of the piping system.
