Impact On Fixed Speed Motor For Pump Mechanical Seal Change
#1 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 15 March 2017 - 02:16 AM
If I propose to change the pump mechanical seal of an existing pump from a single mechanical seal to a dual mechanical seal, will there be any changes in the operating parameters of the existing fixed speed motor of the pump? If yes, what would be those changes, and whether any changes / modifications to the motor are required to be done? Would like to know practical first-hand experience on this, from operations / maintenance engineers.
#2 pavanayi
pavanayi
  • 258 posts
Posted 16 March 2017 - 04:11 AM
its been a while since I was in the plant, but as far as I can recall, I cant think of any parameters that affect the process side. There will be the physical side obviously: space/ seal fluids, startup procedure etc.
Is the pump being re-used for another service?
#3 ankur2061
ankur2061
  • Forum Moderator
  • 2,484 posts
Posted 16 March 2017 - 01:37 PM
No the service remains the same. Dual seal application is considering zero or miniscule emissions. Of course, zero leakage is a practical impossibility but the idea is to ensure that hydrocarbon leak is almost undetectable during normal continuous pump operation over a long duration.
My own understanding is that there will be no impact on the fixed speed motor of the pump. However, just wanted to make sure that my understanding is correct.
#4 Napo
Napo
  • 350 posts
Posted 26 March 2017 - 11:48 AM
Ankur,
In our plant we change 4 pumps of API Plan 21 seal to API Plan Plan53, and we don“t have problems in the electrical motors.
Napo.
#5 Napo
Napo
  • 350 posts
Posted 25 January 2018 - 05:26 PM
Ankur,
I attached a reference from Calculation&Shortcut Deskbook by Chemical Engineering Magazine, USA.
Napo.
#6 breizh
  • 6,925 posts
Posted 25 January 2018 - 08:17 PM
Hi ankur,
You may ring people from John Crane, Burgman, Flowserve for confirmation .
My View
