Submerged Tubes In Heat Exchanger Probleme?
#1 process16
process16
  • 46 posts
Posted 26 March 2017 - 07:10 AM
hello
we did a simulation by HYsis  to know the flow rate of hot oil that we should process  to ansure the out let of crude oil temperature
the heat exchanger  (reboiller)type is shell and tube  AET 1-2
after the simultaion we got that just 83of shell side are full of hot oil
we got this comment on HYsis
(the fraction of the surface area for cooling the liquide phase is estimated to be 83/100 th e  number of naturelly submerged tubes is estimaed to be 1275 thus only 100/100 of the  surface is concidered submerged by the liquide phase )
please i want to know whats the impact in  this  case (83of shell side are full of hot oil ) and  what limit   or percentage we can process with
process parameters are:
hot oil (shell side) T1= 600°F     T2= 372°F
crude oil ( tube side ) t1= 340°F    t2 460°F
thank you
Edited by process16, 29 March 2017 - 03:50 AM.
  • 1,657 posts
Posted 27 March 2017 - 09:15 AM
Be aware that your stated tube side inlet temperature of 3430°F seems likely to cause a multitude of problems that might not be flagged by your Hysys simulation.
#3 srfish
srfish
  • 408 posts
Posted 27 March 2017 - 09:56 AM
I am not familiar with HYsis. but I do know that a AET with 2 tube passes is not normally a reboiler. Also it could not achieve that much of a temperature cross.
#4 process16
process16
  • 46 posts
Posted 29 March 2017 - 03:52 AM
sorry its 340 °F  not 3430 :wacko:
#5 process16
process16
  • 46 posts
Posted 29 March 2017 - 03:58 AM
ok, without considering it as a broiler, what's the impact in the case of that shell is not full of liquid??!
